Wireless Bluetooth Handsfree Car Kit Speaker Phone Sun Visor Panel Clip w/Mic
Wireless Bluetooth Handsfree Car Kit Speaker Phone Sun Visor Panel Clip w/Mic Features: 1.LCD display, caller ID, digital and English subtitles. 2.Voice can be opened to enroll in Chinese or English. 3.One button operation to achieve answer, redial, reject, hang up, and support for voice dialing. 4.Phone book function, support 600 address book import. 5.Store the final answer of 10 phone numbers. 6.Built-in DSP noise reduction and echo cancellation. 7.Solar charger, cigarette lighter, USB charging a variety of ways. 8.High quality Li-ion battery, standby time 300 hours. 9.Charging way:usb cable/Solar Panel 10.Size: 100mm (length) x 55mm (width) x 18mm (thick) Specifications: Bluetooth Version 2.0 Frequency Range 2.4GHz spectrum Transmit Frequency 87.5-108MHz Operation Distance 0-10m Car Charger Input Voltage DC 12-24V Talking Time Up to 12 hours Standby Time Up to 9 days Color Black and Silver Solar Panel Size 62 x 39mm Product Size 110 x 57 x 18mm Pairing: Long press play/pause key for 3 seconds, power your earphone and then hold on for 5 seconds, your will hear 'pairing' then turn on the bluetooth function of your cellphone, search 'HF-I35' connect it. Package Included: 1 X Bluetooth Handsfree Device for Car 1 X USB Cable 1 X Car Charger 1 X Suction Bracket 1 X User Manual Picture details:
Price: 20.99
© 2018.
