VS450 Vgate Code Reader Diagnostic Scan Tool Engine ABS AIR BAG
VS450 Vgate Fault Code Reader Scanner Description: Condition: 100% Brand New Quantity: 1 set (VS450 Scanner,OBD2 Cable,PC cable,Carry Case,manual) Features: - Turn off MILs of Engine,Airbag,ABS,A/T and most other systems - Reset oil service light - Retrieve vehicle information (VIN) - Display I/M Readiness Status - Display DTC definitions on unit screen - System upgradeable via the internet - Highly reliable and accurate - Easy to use with friendly interface - Safely communicates with the on-board computers. - Large,easy-to-read backlit LCD - Stand-alone unit with no need for an additional laptop computer to operate Fitment: Works for any VW-Audi-Seat-Skoda has 16 pin 'OBD2 style' Data Link Connector (DLC),for old-style 2x2 connector (DTC),depends on whether there are 4 or 3 wires connecting to the pins. If there are 4 wires,each connecting a pin,then it will work. If there are only 3 wires,leaving one pin disconnected,then it will not work. Package Includes: 1 x VS450 Scanner 1 x OBD2 Cable 1 x PC cable 1 x Manual 1 x Carry Case
Price: 44.10
© 2018.
