Universal D990 OBD2 Auto Engine Fault Diagnostic Scanner Code Reader
Universal D990 OBD2 Car Auto Engine Fault Diagnostic Scanner Code Reader Feature: 1. Easy to use, highly reliable and accurate tool. 2. Easy to read LCD display, unit fits conveniently fits in the palm or your hand. 3. Works with all 1996 and newer cars & light trucks that are OBD2 compliant. 4. Reads SAE, generic (P0, P2, P3, U0) and manufacturer specific (P1, P3, and U1) Diagnostic Trouble Codes (DTC). 5. Erases trouble codes and determines the malfunction indicator lamp (MIL) status. 6. Displays I/M Readiness Status and state OBD check 7. Retrieves VIN (Vehicle Identification NO.)on 2002 and newer vehicles that support Mode 9 8. Supports VPW PWM ISO9141 protocols 9. Wider vehicle coverage with CAN Protocol 10. Identifies and Displays Pending Codes. 11. Detects OBD2 Freeze Frame Information 12. Code definitions displayed on unit screen. 13. English Interface 14. Large,easy-to-read back light LCD display with adjustable 15. Memory/battery backup for off-vehicle data review and analysis. 16. Detachable and replaceable 16-pin OBD2 cable Support Vehicles: 1.U.S. Models - European - Japanese - Asian - German - Korean: 2.Suitable for almost all cars after 1996. 3.for GM '96 - 2013 (OBD-II) 4.for Ford '96 - 2013 (OBD-II) 5.for Chrysler '96 - 2013(OBD-II) 6.for Toyota '96 - 2013(OBD-II) 7.for Honda '96 - 2013(OBD-II) 8.for NISSAN '96 - 2013 (OBD-II) 9.for All other - Asian and European '96 - 2013(OBD-II) Supported Language: English Specification: Power: directly from the vehicle or by X3 AA batteries (not included) Unit dimensions: 20 x 8.5 x 3cm ( L x W x D) Screen dimensions: 6 x 4.5cm Cable length: 110cm Color: Black Package Included: 1 X D990 Scanner Tool 1 X OBDII Cable 1 X Software CD
Price: 28.99
© 2018.
