Universal 12V 80W Pull/Push Straight Black Blade Electric Cooling Radiator Fan
Feature: 1.ABS plastic,light weight. 2.The unique fan blade design allows you to pull or push air with the same velocity. 3.The motor is easily reversible for any application. Most other fans are designed for one-way air flow. 4.Our fans have ten points for the mounting feet giving you flexible installation options. 5.These truly are slim fans.They measure only 2.5'at the deepest point,making them ideal for cramped areas. Specification: Material: ABS plastic Color: Black Quantity: 1pc Size: 8'/9''/10''/12''/14'' Height: 6.5cm Voltage: DC 12V Power: 80W Air Flow Rate: 2100RPM Wire length: Approx.40cm Package Included: 1 X Electric Radiator Cooling Fan 1 X Mounting Kit Pack
Price: 25.99
© 2018.
