TY-6402 Car Battery Load Tester Analyzer 2V/ 6V/ 12V Battery 4-500Ah Capacity
Description: This product is to judge the lead-acid battery of the tester, can test a variety of automotive batteries, electric vehicle batteries, and other uses of lead-acid battery capacity state, the rapid quality of lead-acid batteries to make good or bad judgments. Products with test switches to facilitate control of test time, the effective protection of the tester and battery. Feature: Plastic shell, metal liner, measuring anti-shock, and anti-drop, long service life. Machine structure was precision, performance and accuracy is more accurate and reliable. Screw fixed copper cable, all copper clip. Soft protective cover, non-slip, anti-shock. Soft silicone cable, soft, and not easy to break. Humanize portable design, easy to measure. High-definition display instrument, scale was clear, more convenient to read the value. Specification: Name: Car Battery Load Tester Analyzer Model: TY-6402 Battery type: lead-acid batteries Measurement of battery specifications: 2V / 6V / 12V Battery rated capacity: 4-500Ah Discharge current during measurement: 2V battery (10A) / 6V battery (30A) / 12V battery (60A) MAX Measurement time: <3 seconds Electric bicycle battery rated capacity: 12 V 10-20Ah Capacity indication: Red area: The battery should be charged immediately Yellow areas: electricity is insufficient should be charged as soon as possible Green area: sufficient power can be normally use Body color: silver + green + black Body weight: about 587g Body size: 200 * 115 * 69.5mm Cable Length: 390mm Clip length: 90mm Package Included: 1 X Car Battery Load Tester Analyzer
Price: 29.99
© 2018.
