Replacement Keyless Entry Remote Fob Transmitter Uncut Blade For Lexus
Replacement Keyless Entry Remote Fob Transmitter Uncut Blade For Lexus Programming: Free programming instructions for the key and remote are provided, in order to use these instructions You must have 1 existing working MASTER key(looks like this one). If you only have a valet key or no keys you cannot program this key yourself, it must be cut and programmed at the dealer. Specifications: Material: ABS Color: Black Quantity: 1 PC 3 Buttons: Lock,unlock and trunk. Case size: 43 x 36 x 10 mm(LxWxH) Blade size: 40 x 7 mm (LxW) With all electronics and a battery installed. Interchange Part Number: 89785-50030 / 89785-50031 HYQ1512V Please use the compatibility chart drop down menu above to double check if this key will work for your car. You must have a factory installed keyless entry system and your original key must look like this one in order for this key to work. Cutting: This key must be laser cut by a Lexus dealer or qualified auto locksmith. Fitment: 1995-2005 Lexus GS300 2001-2005 Lexus GS430 Base Sedan 4-Door 2001-2005 Lexus IS300 2002-2003 Lexus ES300 Base Sedan 4-Door 1998-2000 Lexus GS400 1998-2000 Lexus LS400 Package Included: 1 X Keyless Entry Remote Fob (with blade)
Price: 21.99
© 2018.
