Replacement 4B Prox Keyless Entry Smart Remote Fob for KR55WK49622 285E3-JA02A 285E3-JA05A
Replacement 4B Prox Keyless Entry Smart Remote Fob Uncut Blade for KR55WK49622 285E3-JA02A 285E3-JA05A Specification: Color: Black Weight: 32g Key Width: 9mm Key Length: 68mm Buttons: 4 Lock, unlock, trunk, and panic Interchange Part Number: For KRSSWK48903 ; 315MHz Compatibility 1: FCC ID/part number must match from original remote Compatibility 2: Original must look identical with same buttons Manufacturer Part Number: For 285E3-JA05A; 285E3-JA02A; KR55WK48903 Feature: Insert Blade: Must be cut. It is a replacement remote keyless entry. It also comes with the emergency key insert that will have to be cut to match your car. Compatibility: Works with vehicles listed in my compatibility section above that use a smart key system. Please be sure your original looks identical and has the same FCC ID/part number as listed above. FCCID: KR55WK49622 Fitment: (Vehicles for reference) (Sedan model only please match FCC ID with current key) 2007-2014 Nissan Versa Altima Maxima 2007-2014 Infiniti G35 G37 Q60 Note: Instruction is not included. This remote must be brought to a locksmith or dealer for programming. Please allow 0.5-1 inch difference due to manual measurement.(1 inch=2.54cm) We provide clear pictures, measurements where possible. Please check as much as possible to make sure the item is the one that you need. BEFORE YOU BUY - Please be sure you have a factory keyless entry system. It was not standard on all vehicles. If your current remote looks the same then this will work. If you are not sure then please check with your local dealer. Package Included: 1 X 4 Button Keyless Entry Remote with Uncut Insert Blade
Price: 30.99
© 2018.
