New Key Fob Keyless Entry Car Remote Control Replacement For LTQSAAM433TX
Feature: 1. Complete remote with electronics, battery and an uncut insert blade. 2. It is durable and convenient. 3. Simple design and easy to use. 4. The back of this remote is blank with no logo. Specification: Color Black Size(approx.) 77x40.3x20mm (LxWxT) Material Plastic Frequency 315MHz Button QTY 4 Programming Procedure Dealer or Locksmith to program the remote to your vehicle. Fitment: (The Compatibility Is Just For Reference. Please Compare The Follows With Your Original One before Purchasing.) 2003-2011 Saab 9-3 2004-2011 Saab 9-5 Note: 1.We provide clear pictures, measurements where possible. Please check as much as possible to make sure the item is the one that you need. 2.Please allow 0.5-1 inch difference due to manual measurement.(1 inch=2.54cm) 3.The color of the actual items may slightly different from the listing images due to different computer screen, thanks for your understanding. 4.How to Program: dealer/locksmith programming will be required. 5.No Instructions Included.Professional Installation Is Highly Recommended. Package Included: 1 X Remote Key Specification: Color Black Size(approx.) 77x40.3x20mm (LxWxT) Material Plastic Frequency 315MHz Button QTY 4 Programming Procedure Dealer or Locksmith to program the remote to your vehicle.
Price: 31.69
© 2018.
