Mens Mesh Breathable Baseball Cap With Solar Power Cooling Fan Adjustable Fan Snapback Hat
Feature: 1.The wind can be adjusted by yourself 2.Can be used of green power solar energy and turn the fan on. 3.Suitable for traveling, fishing, climbing, hiking and other outdoor activities. 4.With usb jack, you can directly use the power bank, charger of mobile phone or computer to charge. 5.With 400mah safety explosion-proof lithium battery, fully charged can be used for 8-14 hours continuously. Description: Pattern:Solid Material:Cotton+Polyester Style:Baseball Hat with Cooling Fan Color:Beige,Navy,Grey,Black Feature:Breathable,Detachable Weight:140g Detail In Size: One Size Head Circumference: About 56-59cm(Adjustable) (1cm=0.39Inches) Package Included:1 * Baseball Cap with Cooling Fan More Detail: Beige Navy Grey Black Disclaimer : About Size:Size may be 2cm/1 inch inaccuracy due to hand measure.These measurements are meant as a guide to help you select the correct size. Please take your own measurements and choose your size accordingly.we cannot accept responsibility for incorrect purchases. About Color:The precise color of the items may vary depending on the specific monitor,the settings and the lighting conditions.The items colors depicted should only be used as an approximate guide .
Price: 25.99
© 2018.
