Men Retro Solid Business Leather Belt Waistband Casual Pin Buckle Belt
Description: Feature:Pin Buckle Material Of Buckle: Alloy Material: Gemuine Leather Occasion: Casual,Business Color: Black,Brown,Coffee,Khaki Weight:250g Detail In Size: One Size Belt Windth: 3.7cm / 1.46 inch Belt Length: 125cm / 49.21 inch (1cm=0.39inch) Package Included:1 * Belt More Detail: Brown Khaki Coffee Black Disclaimer : About Size:Size may be 2cm/1 inch inaccuracy due to hand measure.These measurements are meant as a guide to help you select the correct size. Please take your own measurements and choose your size accordingly.we cannot accept responsibility for incorrect purchases. About Color:The precise color of the items may vary depending on the specific monitor,the settings and the lighting conditions.The items colors depicted should only be used as an approximate guide .
Price: 25.88
© 2018.
