Maxiscan MS509 Car Vehicle Auto Scanner Engine Fault Code Reader Tool
Maxiscan MS509 OBD 2/II Car Vehicle Auto Scanner Engine Fault Code Reader Tool Introductions: 1.Automotive diagnostic tool is very important for routine maintenance of vehicles. You can keep your car in a good condition by using these car diagnostic tools. If there is something off with your car, the car scanner tools will help you achieve your automotive diagnosis. The OBD2 Scanner Code Reader is famous for its both easy-using and powerful function like the professional diagnostic tool for car owners. 2.MaxiScan OBD2 Scanner Code Reader Live Data 3.Vehicle Covered: GM '96 - Current Year (OBD-II) Ford '96 - Current Year (OBD-II) Chrysler '96 - Current Year (OBD-II) Toyota '96 - Current Year (OBD-II) Honda '96 - Current Year (OBD-II) NISSAN '96 - Current Year (OBD-II) All other Asian and European '96 - Current Year (OBD-II) Features & Benefits: 1.Works on all 1996 & later OBD2 compliant US, European & Asian vehicles. 2.Easily determines the cause of the 'Check Engine Light'. 3.Retrieves generic (P0, P2, P3, & U0) & manufacturer specific (P1, P3, and U1) codes. 4.Turns off Check Engine Light, clears codes & resets monitors. 5.Displays DTC definitions onscreen. 6.Views freeze frame data. 7.Displays monitor & I/M readiness status (emissions). 8.Identifies pending codes. 9.Reads live PCM data stream. 10.Displays live O2 sensor test data. 11.Graphs data - (1996 and newer). 12.Reads, stores & playbacks live sensor data. 13.Memory/battery backup for off-vehicle data review & analysis. 14.Bilingual interface & definitions-English/Spanish. 15.Performs modules present test. 16.Retrieves vehicle information (VIN, CID and CVN). 17.Supports CAN (Controller Area Network) & all other current OBD2 protocols. 18.Built-in OBD2 DTC lookup library. 19.Large easy-to-read backlit LCD screen. 20.Software upgradeable via internet.Prints data via PC. Specifications: 1. Display: Backlit 128 x 64 pixel display with contrast adjustment 2. Operating Temperature: 0 to 60( 30 to 140 ) 3. Storage Temperature: -20 to 70( -4 to 158 ) 4. External Power: 8.0 to 18.0V 5. Internal Power: 9V 6. Dimensions: 7.01 x 3.74 x 1.38' / 17.8 x 9.5 x 3.5(L x W x H) 7. Color: Red-Black Package Included: 1 x Main unit of Code Scanner 1 x 6-foot OBD II cable 1 x USB cable 1 x CD User's Manual 1 x Carrying Bag
Price: 23.61
© 2018.
