Mass Air Flow Meter Sensor MAF Replacement for Ford Focus Escort XF2F12B579BA
Mass Air Flow Meter Sensor MAF Replacement for Ford Focus Escort XF2F12B579BA Specification: Interchange: 74-50011,86-50011, XF2Z12B579AB, XF2Z12B579BA,XF2F12B579BA, 1L2Z12B579BARM, 1L2Z12B579BA Fit: FORD Focus 2003-2004 2.0L FORD Escort 2003-2004 2.0L FORD Escape 2001-2004 2.0L FORD Ranger 2001-2003 2.3L FORD Escape 2001-2006 3.0L FORD Windstar 1999-2003 3.8L FORD Explorer 1999-2005 4.0L FORD E150 2001-2004 4.2L FORD E250 Van 2001-2004 4.2L FORD Explorer 1999-2001 5.0L FORD Focus 2003-2004 2.0L FORD Escort 2003-2004 2.0L FORD Escape 2001-2004 2.0L FORD Ranger 2001-2003 2.3L FORD Escape 2001-2006 3.0L FORD Windstar 1999-2003 3.8L FORD Explorer 1999-2005 4.0L FORD E150 2001-2004 4.2L FORD E250 Van 2001-2004 4.2L FORD Explorer 1999-2001 5.0L Note: 1.We provide clear pictures, measurements where possible. Please check as much as possible to make sure the item is the one that you need. 2. Please allow 0.5-1 inch difference due to manual measurement.(1 inch=2.54cm) 3.The color of the actual items may slightly different from the listing images due to different computer screen, thanks for your understanding. 4.Instruction is not included.Professional Installation Is Highly Recommended. Package Included: 1 X Mass Air Flow Meter
Price: 21.69
© 2018.
