Keyless Entry Remote Key Start Control Transmitter For Dodge Chrysler
3 Button Keyless Entry Remote Key Start Control Transmitter For Dodge Chrysler Specification: Material: ABS Color: Black 3 Buttons: Lock,unlock and panic. Key size: 8.3 x 4 x 1 cm / 3.26' x 1.57' x 0.39' (LxWxH) Blade size: 49 x 8.5 mm / 1.93' x 0.33' (LxW) With all electronics and a battery installed. Uncut Blade included Your existing key must look the same and have the same button configuration for this to work properly. This key fob is NOT compatible for push to start. You will be able to use this key to start your car and lock/unlock your doors as well as remote start your vehicle. Be sure you existing key looks the same as this one prior to purchasing. Programming: You need 2 existing working keys to program this 3rd key yourself. If you have 0 or 1 keys you will need to have this key/remote cut and programmed to your car at the dealer or automotive locksmith, there is no way to do it yourself. All 2010+ and above vehicles are dealer/locksmith program only. Fitment: 2008-2012 Chrysler Town & Country 2008-2012 Dodge Challenger 2008-2012 Dodge Charger 2008-2012 Dodge Durango 2008-2012 Dodge Grand Caravan 2009-2012 Dodge Journey 2009-2012 Volkswagen Routan 2008-2010 Chrysler 300 2008-2010 Dodge Ram 1500 2008-2010 Dodge Ram 2500 2008-2010 Dodge Ram 3500 Package Included: 1 X 3 Button Remote Keyless Entry Key Transmitter (With blade)
Price: 24.99
© 2018.
