Gas Fuel Brake Footrest Pedal Cap For Audi A4 S4 B8 S4 RS4 Q5 A5 RS5 8T 8R 09-15
Feature: 1.Delicate design,sophisticated craft,durable 2.Pedal cap make of metal material which easy to clean it also has abrasion resistant,corrosion resistance features. 3.The convex part of the pedal has slip resistant feature. 4.Easy installation.No screw mounting required. 5.Fitment: A4/S4(B8) 2009-2015, Q5 2009-2015, A6/S6 (C7) 2012-2015 Specification: Model : 622256 Product name : operation pedal cap Material : aluminum & plastic Main color : black Footrest size : 36cm x 11.5cm (L x W) Brake size : 13cm x 9cm (L x W) Gas size : 11cm x 4cm (L x W) Reference: Gas pedal : 4HF 721 891 Brake pedal : 4H1 723 173 A Foot rest pedal : 8K1 864 777 Installation tips : 1.The gas and brake pedal can be direct replace,no drilling of welding. 2.The foot rest pedal is difficult to install .Professional installation is Highly Recommended. Package Included: 1 X Brake Pedal Cap 1 X Footrest Pedal Cap 1 X Gas Pedal Cap
Price: 32.59
© 2018.
