Front Right Driver Door Lock Actuator Replace for Ford AU BA BF Falcon 1998-2006
Front Right Driver Door Lock Actuator Replace for Ford AU BA BF Falcon 1998-2006 Feature: It is durable and convenient. Simple design and easy to use. Direct fit, Plug and Play. Specification: Color:Black,copper etc Overall Size(approx.):145mm/5.71'(L) (Detail size as shown in the picture) Material:Plastic and metal Placement on Vehicle:Front right driver Manufacturer Part Number:BAFF26412A Fitment:(The Compatibility Is Just For Reference. Please Compare The Follows With Your Original One before Purchasing) For Ford Falcon AU BA BF Suit Ute Sedan and Wagon 1998 - 02/2006 with black circular arc plug. If your car is built after Feb 2006 with gray square plug, this item will not fit. Note: 1.We provide clear pictures, measurements where possible. Please check as much as possible to make sure the item is the one that you need. 2.Please allow 0.5-1 inch difference due to manual measurement.(1 inch=2.54cm) 3.The color of the actual items may slightly different from the listing images due to different computer screen, thanks for your understanding. 4.No Instructions Included.Professional Installation Is Highly Recommended. Package Included: 1 x Door Lock Actuator
Price: 41.99
© 2018.
