FM28B Bluetooth Wireless Auto FM Transmitter 5V 2A Adapter with Remote Control
FM28B Bluetooth Wireless Auto FM Transmitter 5V 2A Adapter with Remote Control Description: The FM transmitter FM28B Bluetooth Car FM is installed with a high-performance Bluetooth module and a sophisticated decoder chip MP3 / WMA. You can play music from micro SD and the mobile phone through the car stereo via FM radio transmission. You can enjoy music and answer phone calls at the same time easily via Bluetooth. Features: 1. Volume Of adjustment to 360 degrees and answer calls at the top separate button Easy 2. Can Adjust the angle at random, suitable for several vehicles 3. IN music -Support MP3 / WMA / WAV format 4. Bluetooth Hands free 5. Support Play stereo music via Bluetooth 6. Stereo Bluetooth and FM transmitter 7. Supports Power supply to other devices via USB and the Max 5V / 2 A output 8. Support IR remote control to answer a call or switch calls Specification: Product Name Bluetooth Receiver Color Black Dimensions About 10x8.5cm / 3.93 'x3.34' Weight 157g Rated voltage 12V Limited voltage 9 ~ 26V USB Output 5V / 2A Work Temperature 0 ~ 50 Bluetooth transmission distance 10m FM transmit frequency 87.5 ~ 108Mhz Frequency response 20Hz-15Khz Degree of distortion <0.1% SNR > 60dB Package Included: 1 X Bluetooth Receiver 1 X Remote Control 1 X User Manual
Price: 23.19
© 2018.
