Compression Tester Kit For Diesel Engine Direct & Indirect Injection Engines
Feature: 1. Use to identify worn valves and piston rings. 2. Includes adaptors for most diesel cars,vans,trucks & tractors. 3. Easy to read dial gives an accurate measurement of individual cylinder pressures up to 70 bar. 4. No Item Length Thread. 5. Use this tool kit to identify worn valves and piston rings of most diesel cars, trucks and tracktors. Specification: Color Black Material Carbon Steel Box Size 37.5cm*27cm*7cm Package Included: 1 X Glow Plug Adaptor 91mm M10X1 1 x Glow Plug Adaptor 119mm M10X1 1 x Glow Plug Adaptor 135mm M10X1.25 1 x Glow Plug Adaptor 118mm M22X1.5 1 x Disal Gauge 340mm 1 x Glow Plug Adaptor 113mm M10X1 1 x Glow Plug Adaptor 102mm M10X1 1 x Glow Plug Adaptor 83mm M10X1 1 x Glow Plug Adaptor 64mm M10X1.25 1 x Glow Plug Adaptor 47mm M12X1.25 1 x Screw Adaptor 160mm 1 x Injector Adaptor 88mm M24X1.5 1 x Injector Adaptor 73mm M22X1.5 1 x Injector Adaptor 63mm M24X2 1 x Injector Adaptor 75mm M20X1.5 1 x H Fitting 1 x Bleed Valve
Price: 64.59
© 2018.
