Clear Heated Wing Mirror Glass for Left Driver Side for Jeep Grand Cherokee 2005-10
Feature: 1. Backing plate & heating element included. 2. This mirror is the HEATED version. 3. Mirror glass is real glass - not plastic. 4. Very easy to fit just clip straight. No DIY required. 5. Durable and easy to install. Description: Glass Color: Clear Side: Left Driver Side PIN: 2 Heated: Yes Size: 21.2x12.7cm (LxW) Fitment: Fits for Jeep Grand Cherokee 2005-2010 Note: 1. We provide clear pictures, measurements where possible. Please check as much as possible to make sure the item is the one that you need. 2. Please allow 0.5-1 inch difference due to manual measurement.(1 inch=2.54cm) 3. The color of the actual items may slightly different from the listing images due to different computer screen, thanks for your understanding. 4. No Instructions Included.Professional Installation Is Highly Recommended. Package Included: 1 X Left Mirror Glass
Price: 21.69
© 2018.
