Car OBD2 GPS Tracker with Fault Diagnosis and Fuel Consumption Monitoring Function
Description: This product can remote monitor any fault and location of vehicle with GPS.The product uses the high quality chip, high integration, low power circuit design, compact shape, easy to use, fast response speed, support a variety of vehicle protocol.Support automotive real-time data and statistics data, the stability is high. Mechanism: OBD Part 1. Driving mileage of this time 2. Total mileage 3. Instantaneous fuel consumption 4. Fuel consumption per hundred kilometers 5. Average fuel consumption 6. Fuel consumption of this time 7. Cumulative fuel consumption 8. Cumulative driving time 9. Cumulative idling time 10. The average heating time 11. Driving time 12. Speed 13. Engine speed 14. Engine average speed 15. Maximum engine speed 16. Water temperature 17. Coolant temperature 18. Engine load 19. Throttle opening 20. The total number of ignition 21. Collision warning 22. Vehicle fault codes 23. Battery voltage GPS/GSM/GPRS Part 1. 850/900/1800/1900 four frequency global universal 2. Support GPRS/SMS monitoring, support for TCP/UDP transmission 3. Support GPS blind areas AGPS auxiliary positioning 4. Voice monitoring 5. Scroll to save the last half hour black box track record data 6. USB setup / upgrade 7. OTA Remote upgrade 8. Fixed time report Fixed distance reporting Direction trigger Report 9. Time / direction / ACC switch / speed / mileage / power status Alarm: 1. Overspeed alarm 2. Power off alarm 3. Electronic fence cross-border alarm 4. Low battery alarm 5. SOS emergency alarm Control: 1. Remote monitoring 2. Remote setting, query parameters 3. Remote Reboot 4. Remote voice monitoring 5. Remote clear alarm 6. Remote upgrade Package Included: 1 X OBD2 GPS Tracker 1 X User Manual
Price: 34.49
© 2018.
