Car GPS Tracker GSM/GPS Car Charger Car Locator Cell Phone Car Charger
Car GPS Tracker GSM/GPS Car Charger Car Locator Cell Phone Car Charger Description: This car tracker can support a lot of country: United Kingdom France Germany Netherlands China Italy, Spain and Portugal Brazil, Denmark and Russia Poland, Turkey and Hungary Thailand, Greece and Indonesia Malaysia, Myanmar, Pakistan and Iraq Arab and American Kazakhstan. Specification: 1. Machine Battery: 3.7V 400mAh Li-ion battery 2. Standby time: 12 days. Working time 4-6 days 3. Expansion card; mini TF card 4. Continuous call: 150-180 minutes 5. Network standard: GSM / GPRS 6. Storage Temperature: -40 C to + 85 C 7. Operating temperature -20 C to + 55 C 8. The relative humidity range 5% - 95% non-condensing 9. Frequency: GSM850 / 900/1800 / 1900MHZ Instructions: 1 First, buy a new SIM card to open GPRS1 preparation: a SIM phone card 2. Boot: Open the card cover in the direction indicated SIM card is inserted in the mini memory card is inserted, the product will automatically turn the red light flashes four times, 30 seconds into the normal standby state. 3, binding master number; send to the alarm locator number 000 edit the text using a mobile phone, mobile phone later on this machine reply text message; Set; bindings + master number The separate recording; alarm locator number sent to edit the text using a mobile phone 555, later in this machine phone text message reply; [Snd; recording has begun] 5. Voice Callback; edited using a mobile phone to send text messages to the alarm locator number 666, later in this machine a text message reply to the phone; [DT; has successfully set sound monitoring, alarm call-back]. When the alarm locator ambient sound greater than 40 decibels of sound, alarm locator will automatically call the preset phone number. 6.GPRS location query: send 777 to edit the text using a mobile phone alarm locator number, phone a reply later in the machine location and the Google Maps link, will appear after the phone is open this link address location map and text description of the position more accurate. 7. host state; edited using a mobile phone to send text messages to the alarm locator number 888, later in this machine a reply to phone messages. 8. Restart the host; alarm locator number sent to edit the text using a mobile phone 999, and so one minute recovery success. 9. Remove the memory card content; send to the alarm locator number 445 edit the text using a mobile phone, a mobile phone later on this machine to reply; [TF, cleanup is successful, the current may have the capacity] 10. Close function; send to the alarm locator number 444 edit the text using a mobile phone, a mobile phone later this machine reply, [Reset; all tasks have been canceled] 11. Product ambient sound check: direct dial alarm locator card number, can open up after a few seconds to hear the sound around the alarm locator (query alarm locator itself does not emit any sound and light) 12. Indicator: Power indicator light goes out four times, low battery indicator flash. Notice: 1. Host Unreachable A: You must insert SIM phone card will enable mobile phone signal switched, so you just need to reboot the machine after customs clearance. There is not a server on your phone card, there is no signal. 2. TF memory card can not be saved? A: First check TF memory card is wrong problem, no problem if TF card can be formatted at TF memory card and try again. 3 can not be charged? A: To charge shall be inserted GSM card can not be achieved if there is no charge. 4 What is the master phone? A: what you need to use it to monitor burglar alarm phone. Package Included: 1 X Car GPS Tracker Product Details:
Price: 25.19
© 2018.
