Car Faux Leather Touch Activated Ultra LED Light Shift Knob Multicolor
Description: Support for multiple screw size by 8,10,12MM. With Cigarette lighter plug and use Circularly. There are LEDs that are built into this shift knob which are activated by simply touching it. The LED light will stay on for 30 seconds and automatically turn off afterwards. The LEDs are powered by an internal battery source which is rechargeable. A charger is included in this package so you can recharge it with the car cigarette lighter outlet. It is easy to install. Remove the original car stalls head. The head of this stand aluminum cap from the bottom. Take pouches suitable for the size of the shift lever. Into the shift lever inside the sleeve The gear head directly set into the stand rod. Tighten the hexagonal screws,The aluminum cover can be tightened up. Function:When touch the gear head, the LED lights in Multi-colorful. Package Included: 1 X Car Shift Knob
Price: 24.99
© 2018.
