Car Bluetooth Speaker Audio Stereo FM Aux Input Receiver SD USB MP3 Radio Player
Car Bluetooth Speaker Audio Stereo FM Aux Input Receiver SD USB MP3 Radio Player Features: 1. Flip down fixed front with elegant carry case. 2. With SD card slot with USB 2.0 port. 3. Support 512M/1G/2G/4D/8G memory card extention. 4. Support the playback format of MP3. 5. FM radio. 6. Stereo electronic tuner,scam& store stations automatically. 7. Electronic tuning more than 3 bands (FM1.FM2,FM3) and 18 preset stations. 8. Power-off with auto-memory store function under radio or USB mode. 9. LCD colorful display. 10. Many kinds of sound effects can be selected,DSP audio control. 11. Multi-functionIR remote control. Specification: FM frequency range 87.5-108.0MHZ Medium frequence 10MHz Voltage 12V Output power 4x50W(Max.) Loudspeaker impedance 4-8 Shell size 18.5cm x 10.5cm x 5.5cm { about 7.28'' x 4.13'' x 2.17''} Package size 21cm x 18cm x 8.5cm { about 8.26'' x 7.08'' x 3.34''} INSTALLATION: 1.Press the hook lock of the metal case,and insert the metal case into panel board. 2.Then,push the device into the metal case until lockup. NOTE: 1.The device is 12 volt ,pls check the DC voltage on your car before you install the device. 2.In order to avoid electrical short-circuit ,pls connect fround wire with battery negative. 3.Pls confirm the install wires connection is done properly. 4.Pls use high quality loudspeakers of 4-8 . Package Included: 1 X Car MP3 Player 1 X Remote Control 1 X Connecting Wire 1 X User's Manual
Price: 20.44
© 2018.
