Car 3 Button Uncut Ignition Key Keyless Entry Remote Fob 4C Chip for Lexus GS300
Car 3 Button Uncut Ignition Key Keyless Entry Remote Fob 4C Chip for Lexus GS300 Features: It is durable and convenient. Simple design and easy to use. Specification: Color: Black Overall Size(approx.): 84.3mm/3.31'(L) Thickness: 14mm Material: Plastic Button QTY: 3 Frequency: 315Hz Transponder Chip 4C Battery: 3V CR2032(Lithium cell) Manufacturer Part Number: For 89785-50030 / 89785-50031 HYQ1512V Interchange Part Number: For 89785-50030 / 89785-50031 HYQ1512V Other Part Number: For 89785-50030 / 89785-50031 HYQ1512V Programming Procedure: Dealer or Locksmith to program the remote to your vehicle Fitment:(The Compatibility Is Just For Reference. Please Compare The Follows With Your Original One before Purchasing.) Fit For 1995-2005 Lexus GS300 2001-2005 Lexus GS430 Base Sedan 4-Door 4.3L 4293CC V8 GAS DOHC Naturally Aspirated 2002-2005 Lexus IS300 2002-2003 Lexus ES300 Base Sedan 4-Door All 1998-2000 Lexus GS400 1998-2000 Lexus LS400 Note: 1.We provide clear pictures, measurements where possible. Please check as much as possible to make sure the item is the one that you need. 2.Please allow 0.5-1 inch difference due to manual measurement.(1 inch=2.54cm) 3.The color of the actual items may slightly different from the listing images due to different computer screen, thanks for your understanding. 4.How to Program: dealer/locksmith programming will be required. 5.No Instructions Included.Professional Installation Is Highly Recommended. Package Included: 1 X Key(with battery) 1 X Transponder Chip
Price: 20.69
© 2018.
