Car 2 or 4 Doors Central Lock Locking Keyless Entry System Kit & Remote Keys Fob
Car 2 or 4 Doors Central Lock Locking Keyless Entry System Kit & Remote Keys Fob Features: -The latest 360 degree full rotational heads and hard wearing -Silent high torque motors give over 100000 operations with a 4kg force. -Has the option at connect to internal door switches for added convenience. -Full REMOTE operation. -Unlocks / locks all your car doors from up to 30 metres away. -Waterproof and shockproof. We fit these to off-roaders. -Master solenoid. Gives the driver full control from the door switches. -Wide temperature operation. These can operate from -40 to 85 degrees Celsius. -Compatible with all cars and alarm system. No special adapters required here, unlike some. Specification: Color: Black Actuator Material: Plastic Voltage: 12V DC Temperature: -20 to +70 deg. C Current consumption: 0.15 to 2.22A Endurance (up and down): 100,000 times Push and pull force: 4kg Fitment: Fits all vehicles-direct gear gun type (2 or 4 Door) Package Included : 2 X High Grade Metal Remote Control Units 1 X Master Actuator/motor 5 Wire 3 X Slave Actuator/motor 2 Wire 1 X Main Brain Unit 1 X Wire Loom 4 X Metal Brackets and Fittings 1 X Wiring Instruction
Price: 32.99
© 2018.
