Car 2 or 4 Door Central Lock Locking Keyless Entry System Kit Remote Key Fob
Car 2 or 4 Door Central Lock Locking Keyless Entry System Kit Remote Key Fob Description: This kit will solve that your car have no central locking or existing system is broken and give you a total new feel and way to locking and unlocking your vehicle. With the LATEST DESIGN key fobs you can open or close your car up-to 30 meters away. These kits are suitable as a DIY job. Features: Full REMOTE operation. Waterproof and shockproof. We fit these to off-roaders. The latest 360 degree full rotational heads and hard wearing. Unlocks / locks all your car doors from up to 30 metres away. Master solenoid. Gives the driver full control from the door switches. Silent high torque motors give over 100000 operations with a 4kg force. Has the option at connect to internal door switches for added convenience. Wide temperature operation. These can operate from -40 to 85 degrees Celsius. Compatible with all cars and alarm system. No special adapters required here, unlike some. Specification: Color: Black Actuator Material: Plastic Voltage: 12V DC Temperature: -20 to +70 deg. C Current consumption: 0.15 to 2.22A Endurance (up and down): 100,000 times Push and pull force: 4kg Fitment: Fits all vehicles-direct gear gun type (2 OR 4 Door) Package box size: about 22.5cm(L) x 13.3cm(W) x 8.5cm(H) Note: 1. Please check the size measurement chart carefully before making payment. 2. Please allow 0.5-1 inch difference due to manual measurement.(1 inch=2.54cm) 3. The color of the actual items may slightly different from the listing images due to different computer screen, thanks for your understanding. 4. Instruction is included. Package Included : 2 X High Grade Metal Remote Control Units 4 X Metal brackets and Fittings 3 X Slave Actuator/Motor 2 wire 1 X Master Actuator/Motor 5 wire 1 X Main Brain Unit 1 X wire loom 1 X Wiring Instruction
Price: 32.99
© 2018.
