C-110 Car OBD2 Diagnostic Scanner Fault Code Reader Scan Multi-System Tool
Feature: 1. Show up to 2 reviews by default 2. C110 Code Reader supports for BMW between 2000 to 2014 years. Function includs read trouble codes, clear trouble codes, displays live data stream, clear adaptation and vehicle information. Add MINI Cooper test function. If your car is before 2000, you may need a 20 Pin adaptor which is not included in the package 3. Version: V3.3 4. Language:English/Germany 5. Supported car model: 6. For BMW 1 Series, 3 Series, 5 Series, 6 Series, 7 series, 8 series, X series, Z series and Mini Function: Read trouble codes, clear trouble codes, displays live data stream, Component Testing, Clear adaptation and vehicle version information. Applicable system include: DME, EGS, ABS, SRS, IHKA/IHKR, IKE/IKI/KOMBI, EML, SPM/SM, EWSZKE, GR, PDC, SZM, BIT, LSZ/LCM, LEW, RAD, EHC/EDC, BM, AIC, NAV, MFL, VID, SES, MID, SHD, SMF, SPMBT, SPMFT, VTG, CID, EPS, SBSL, SBSR, CVM, SIM, SMB, URS, RDC, VMX, VNC, EKM, DWA, XEN, FHK, GSA, AHK, ADS, CAS, DME, EGS, VTC, HPFI, ACC, ARS, CIM, DSC, EDC, EHC, EMF, RDC, AHL, AHM, AMP, ASK, SZM/BZM, FBZM, CD, CD-GW, SG-FD, SG-FD- GW, FD, CDC, CON, FCON, DWA, FBI, IHKA, FKA, HKL, JBIT, KHI, KOM, LM, DVD-C, NAV JNAV, PDC, CA, PM/MPM, RLS, SASL, SASR, SBSL, SBSR, SFZ, SSBF, SSFA, SSH, STVL STVR, SHD, SINE, SMFA, SMBF, SMFAH, SMBFH, SHZH, SVS, SZL, SEC, TEL, TCU, TMBF T, TMBFH, TMFAT, TMFAH, VM, WIM, ZGM, SIM, KBM, SBSL, SBSR, TMFA, TMBF, CID, AL JBE, MRS/ACSM, FRM, RLS, FZD, CCC-ANT, DDE, CCC-A, EKPS, GWS, VTG, VTC, VTC2, CCC-ASK, AL, EDCSHL, EDCSHR, EDCSVL, EDCSVR, VDM, ACSM, AMPH, AMPT, CA, CCC-BO, CCC-GW, CHAMP-BO, CHAMP-GW, CNAV, DAB, FD, FLA, FRM2, FZD, HUD, IBOC, IHKA, INS TR, JBE2, KHM, KNAV, M-ASK-BO, M-ASK-GW, RFK, RLSS, RSE, SDARS, SINE, ULF-SBX, ULF-SBX-H, VSW, EHC, ULF, IHKR, IHR, M-ASK-NAV, MRS, RAD2-BO, RAD2-GW, SDMRS, DME2, ACC2, ANT, ARS, BZM, CD, CEM, CIM2, LM2 AHL2, LM2, LM2, NVE, NVK, PM, SEC 2, SGM-SIM, SGM-ZGM, VTC2, ZBM, DSC, DSC, ALBBF, ALBFA, CIC, CIC-GW, IHKA2, KGM, SZL2, LDM, LRR, MPM, SMG, TLC, Integrate Chas Manag, Rol-mo dis, rear axle, ABS /ACS/DSC, AMP, IHKS, IHS, MJOY, AIRBAG, EWS. Package Included: 1 X C110 Code Reader 1 X USB Cable 1 X User Manual
Price: 46.99
© 2018.
