Auto Car Stereo MP3 Radio Audio Player In-Dash FM Transmitters Aux Input Receiver SD USB
Auto Car Stereo MP3 Radio Audio Player In-Dash FM Transmitters Aux Input Receiver SD USB Features: LCD colorful display. Multi-functionIR remote control. With SD card slot with USB 2.0 port. Support the playback format of MP3. Support 512M/1G/2G/4D/8G memory card extention. Stereo electronic tuner,scam& store stations automatically. Power-off with auto-memory store function under radio or USB mode. Specification: Voltage 12V Medium Frequence 10MHz Loudspeaker Impedance 4-8 FM Frequency Range 87.5-108.0MHZ Size 18 x 14 x 5.5cm Note: 1.The device is 12 volt ,pls check the DC voltage on your car before you install the device. 2.In order to avoid electrical short-circuit ,pls connect fround wire with battery negative. 3.Pls confirm the install wires connection is done properly. 4.Pls use high quality loudspeakers of 4-8 . 5. This product do not support Bluetooth. Package Included: 1 X Car MP3 Player 1 X Remote Control 1 X Connecting Wire
Price: 25.69
© 2018.
