ABS Holder Housing Kit Rocker Switch LED Dual USB Port For Car Marine Boat
Feature: 1.With pre-wired,blue led rocker switch can control the 4.2A (2.1A+2.1A) USB port socket to work. Only need to connect the red line to '+' of the power and black to the ground ,the panel kit will begin to work. 2.Designed to give more strength when mounting power socket and USB charger in your dash. Can be used on various vehicles and boats, SUV, ATV, UTV, Marine. 3.Easy to use and install. Over-heated protection, over-current protection, over-charging protection, Mounting size (LxW): 4.37'x 2'. 4.Environmental ABS material. rocker style switch housing houlder makes the installation more easier. 5.The 3 pins led rocker switch and 4.2A double USB port can also been mounted separately. Package Included: 1 X 4.2A dual USB adapter 1 X Cigeretter Socket(can not smoking) 1 X Rocker Switch 3 X Housing Holders And Jumper Wires Specificaiton: Dual USB Color Black LED light Blue Input DC12-24v Output voltage DC 5V Output current 2.1A/2.1A Cigarette Lighter Power Socket Color Black LED light Blue Input 12V-24V Loop Circuit ON-OFF Switch System Water-resistant enclosed Rocker switch Rating DC 12V 20A, 24V 10A Dielectric Strength AC 1500V 1 minute Operating Temperature -25degree to 80degree Electrical Life 10000 make and break cycles at full load
Price: 21.89
© 2018.
