9inch Slim Reversible Electric Radiator Cooling Fan Push Pull 12V 80W
9inch Slim Reversible Electric Radiator Cooling Fan Push Pull 12V 80W Feature: 1.ABS plastic,lightweight. 2.The unique fan blade design allows you to pull or push air with the same velocity. 3.The motor is easily reversible for any application. Most other fans are designed for one-way air flow. 4.Our fans have ten points for the mounting feet giving you flexible installation options. 5.These truly are slim fans.They measure only 2.5inch at the deepest point,making them ideal for cramped areas. Specification: Condition 100% brand new Material ABS plastic Color Black Quantity 1 pc Size 9inch Thickness (Motor Height) 2.5inch Air Flow Rate >1130 CBM/Hr Speed 2100 RPM Volt DC 12V Power 80W Wire length Approx.40 cm Package Included: 1 X Electric Radiator Cooling Fan 1 X Mounting Kit Pack
Price: 30.99
© 2018.
