98-03 Electric Power Window Master Switch Console for MERCEDES ML430 ML320 ML55
98-03 Electric Power Window Master Switch Console for MERCEDES ML430 ML320 ML55 Specification: Color: Black Position: 8 Weight: 307g Size: 110mm*105mm*140mm Package Size: 15cm*14cm*6cm OEM Part Numbers: 1638206610,A1638206610 ; 163 8206610 ; 163 820 6610,163 820 66 10 ; A 163 820 66 10 ; A163 820 6610 Features: Direct replacement. 8 Button Master Switch. Center Console Mounted. Built to strict quality control standards. Controls power window and side mirror functions. Have the same function and appearance as the original. This switch is a complete unit you need, including buttons, circuit boards, plug-ins. Fit the Following Cars: 1999-2003 Mercedes ML320 3.2 V6 112.942 1998 Mercedes ML320 3.2 V6 1999-2001 Mercedes ML430 4.3 V8 113.942 2000-2003 Mercedes ML55 AMG 5.5 V8 Note: 1. We provide clear pictures, measurements where possible. Please check as much as possible to make sure the item is the one that you need. 2. Please allow 0.5-1 inch difference due to manual measurement.(1 inch=2.54cm) 3. Instruction is not included. Package Included: 1 X Electric Power Window Master Switch
Price: 40.69
© 2018.
