7Inch TFT LCD Car Rear View Monitor VGA DVD VCR For Reverse Backup Camera
7Inch TFT LCD Color Car Rear View Monitor VGA DVD VCR For Reverse Backup Camera Specification: Interface: AV 2-way video input (which can add reversing the priority function) Screen size: 7 inches (mm) 154 (H) x 86.5 (V) LCD Screen Aspect Ratio: 16:9 (can be set to 4:3) PAL / NTSC system is adaptive Screen up and down, left and right rotation Viewing Wide Angle: 70/70/50/70 (left / right / up / down) Supply Voltage: DC 12V Brightness: 400 contrast ratio: 350:1 Pixel (mm) 0.1926 0.1790 Best Resolution: HD 800 (rows) 480 (field) to support up to 1024 * 768, 1280 * 1024. Current consumption: 500mA Power consumption: 7W Operating temperature: -20 C - +65 C Storage temperature: -25 C - +85 C Dimensions L * W * H: 173 113 21mm The headrest frame Dimensions L * W * D 193X134X30mm Embedded hole size (Reference) L * W * D 185 * 118 * 28mm Net weight: 500g Seismic rating: 5 Package Included: 1 X 7 Inch Car Monitor 1 X Bracket 1 X Power Cable 1 X Remote Control 1 X User Manual
Price: 31.99
© 2018.
