7 inch Car GPS Navigation Audio Player FM USB SD AUX Bluetooth Touch Screen Panel In-Dash Android Universal
Description: 1. CPU 1.6G + 16G + 7388 IC 2. Android 4.4.4 operating system 3. 1G DDR3, support 8G / 16G iNAND 4. WIFI Built-in, support WIFI hotspot. 5. Support phonelink function. 6. Support HD screen (1028 * 600) 7. Support capacitive touch screen, support multi-touch. 8. Support internal and external GPS map. 9. Support 2-way SD card, 3-way USB interface. 10. Supports Internet APP download, install, uninstall. 11. Support rear view camera input; vehicle information display, reversing trajectory. 12. Built-in Radio, FM / AM / RDS. 13. Built-in Bluetooth, phonebook and A2DP BT music. 14. Built-in GPS / Compass dual-mode navigation module. 15. Multi-format audio and video decoding, support 1080P full-format, video playback up to 4K. 16. OSD Language: English / Russian / French / German / Spanish / Italian / Arabic / Portuguese / Turkish / Thai / Polish / Hebrew 17. Memory + no analog TV function, no DVD player, no remote control, no recorder function. Note: Pls confirm the fit item if it matches your models before you purchase. Package Included: 1 X 7 inch Car GPS Navigation Audio Player 1 X Power Cable 1 X GPS Antenna 1 X Operation Manual
Price: 159.99
© 2018.
