600A Cars Trucks Emergency Battery Cable Car Auto Power Jumper Booster Cable Emergency Ride Firewire
Description: 1. 600 AMP 2. Durable Wire Cable 3. Cable Length: 3.6m 4. Easy and convenient to use 5. Material:Copper Coated Aluminum. 6. Made from high end copper clad aluminum 7. Copper end clamps with rubber-coated handles for protection 8. Full set (one positive cable with 2 clamps and one negative cable with 2 clamps) 9. Handy carring case included for storage and portability 10. Wires are coated with thick yet flexible insulation, offering kink-free flexibility 11. Weather resistant: can handle weather temperature variations 12. Heavy duty Booster cable comes with 500-Ampere copper plated jaw clamps for excellent contact and battery transfer. It generally suits for storage battery between gasoline engine with displacement less than 2500cc or a diesel engine with displacement less than 2000cc. Note Two vehicles can not have any contact,and two car electronic system must have the same voltage. If the battery is frozen, do not use this cable. Before connecting, engine, stereo, and air conditioning of two vehicles are required to turn off. How To Connect : (1) First, the Red wire clamp 'rescued the car,' the Red positive battery. (2) the Red wire clamp 'rescue vehicle,' the Red positive battery (3) the black wire clamp 'rescued the car,' the black negative battery. (4) Then the black wire clamp in the 'rescue vehicle' black negative battery. (5) Start the 'rescue vehicle' of the engine, and then start 'rescued the car,' of the engine. If you find rescued car still does not start,Please check if the metal contact parts are bad. When finished start the engine, still need to take in order to start removing the line of fire, or they may cause a short circuit. Line removal procedure is as follows: (1) First, the 'rescued car' black wire removed. (2) then 'rescue vehicle' black wire removed. (3) and then removed 'rescue vehicle' red wire. (4) Finally, the 'rescued car' red wire removed Package Included: 1 X One Set of Booster Cable
Price: 31.19
© 2018.
