4 Buttons Remote Flip Key Fob Keyless For Jaguar S-Type XJ8 X-Type With Battery
4 Buttons Remote Flip Key Fob Keyless For Jaguar S-Type XJ8 X-Type With Battery Features: Stylish black appearance. Small and convenient. Easy to install. A perfect aftermarket replacement. Specification: Color: Black Material: Plastic Button: 4 buttons Battery: Button battery Weight: 57g Quantity: 1 piece Blade Length: 3.5 cm Shell Size: 7.1*3.5*1.5 cm Fitment: 2001-2008 Jaguar S-Type 2001-2008 Jaguar XJ8 2002-2008 Jaguar X-Type Package included: 1 x Flip Key Shell (With buttons) Note: 1. Please make sure that your key and blade fits exactly the same as above specifications, otherwise this product is not a best choice. 2. Please check your car model before your purchase. 3. The key blade needs to be cut. You can find your local dealer, or qualified locksmith which is much favorable than the dealer.
Price: 25.99
© 2018.
