4 Button Remote Key Case Shell FOB Uncut Blade For Jaguar X type S
4 Button Remote Key Case Shell FOB w/ Uncut Blade for Jaguar X type S type XJ Features: Brand new key case with uncut blade, Internal (buttons / transponder chips / battery) are included Easy installation, if you use your old remote then there is no programming require Direct fits, get the blade cut at any locksmith or swap the blade A perfect replacement for your damaged/worn remote key FOB does not come with any emblem or logos Specifications: Color: Black Button: 4 Buttons Length: 70mm/2.75' Width: 38mm/1.5' Height: 2mm/0.79' Quantity: 1 piece Fitment: Pls confirm the shape of your remote key is the same as the below pictures showed. JAGUAR X type/ S type/ XJ type Package Included: 1 x Remote Key With Uncut Blade For JAGUAR
Price: 35.92
© 2018.
