370 Clips Bumper Trim Panel Body Fastener Retainer Assortment Kit For Mitsubishi
Feature: 1.These rivet fasteners are made of nylon material, suitable for car use. 2.Cars accessory, commonly used for fitting side skirts, bumpers and other trim. 3.Push Type Retainer Kit came with a nice plastic box for easier to pick a type of retainer that you want to use. 4.Save yourself time and money.No need to go to a auto parts store and look for different fasteners. 5.Need not worry about lost or damaged body fasteners.All the necessary retainers for exact replacement of old and broken retainers. 6.Before you buy, please see the product number, size, color, model. Specification: Rivets Material Plastic Color As shown in the picture Other Part Screw Fender Body Door Trim Panel Hood Interchange Part Under Engine Splash Guard Rivet Fastener Clips Manufacturer Part Plastic Push-Type Bumper Retainer Clip Applications 1 Defender Door Card Interior Weatherstrip Moulding Applications 2 NYLON CHRISTMAS TREE Carpet Floor Mat Clips Type:12 differnt type H15:50PCS K04:50PCS K47:30PCS K46:30PCS K45:30PCS C26:10PCS C23:15PCS F40:40PCS K99:15PCS D199:40PCS B02:20PCS D04:40PCS Package Included: 250 X Plastic Clips Fasteners(with plastic Storage Box ) 1 X Clasp Forceps
Price: 20.39
© 2018.
