300Pcs 15 Sizes Car Push Pin Rivet Trim Fastener Clips Body Interior Assortment
Feature: 1.15 Type plastic rivets for your choice 2.Cars good accessory 3.Great for door trim 4.Applicable models: Nissan Honda Buick Specification: Type: HE34 Material: Plastic Package Size: 275x165x55mm Size Chart : Quantity---Fit Hole Size-----Head Diameter---Stem Length C07----20pcs--6mm---15mm--10mm B14----20pcs--8mm---20mm---11mm B17----20pcs--9mm---18mm---28mm B28----20pcs--8mm---20mm---20mm B02----20pcs--10mm---20mm---13mm B57----20pcs--6.3mm---17.2mm---23mm B18----20pcs--8mm---20mm---9mm B01----20pcs--10mm---20mm---18mm Quantity---Fit Hole Size A16----20pcs--6.4mm A133----20pcs--9mm B105----20pcs--6.3mm A10----20pcs--7.1mm A55----20pcs--9.5mm A82----20pcs--7.8mm A102----20pcs--10mm Package Included: 300 X Car Push Pin Rivet
Price: 21.29
© 2018.
