12V Car Engine Push Start Button Remote Control RFID Lock Ignition Starter Kit
Feature: 1.A key to open sound and panel. 2.A key to start and stop the car. 3.Remote start the car. 4.10 minutes countdown stop the car. 5.Hand brake testing interface. 6.Cab use with alarm. 7.A burglar cut-off interface. 8.Working current: 3mA. 9.Remote start at the same tine to lock the door. 10.Immobilizer, with warded lock card anti-theft function, the system will enter arming mode after 15 seconds automatically when car is stopped. 11.In arming mode, when the responder gets close to (about 2 - 5cm) the wire circle, the system will sound Bi Bi, which indicates the system is disarmed. 12.Durable and Portable. 13.Easy to install and to detach. 14.Can be matched your car alarm system or keyless entry system. 15.Smart RFID Car Engine Alarm Finger Push Starter. 16.Push Starter is easy to install and use, can start or stop your car much easier and keep your car safe at the same time. 17.This item is only work with DC12V cars. Specification: Color: Black Material: ABS + Electronic Components + Metal Voltage: DC 12V Package Included: 1 X Car Engine Push Starter Host 1 X Push Start Stop Button (1m Cable Length) 1 X RFID Sensor Ring (1.2m Cable Length) 2 X RFID Key 2 X Wire (0.6m/1m) 1 X English User Manual
Price: 34.59
© 2018.
