12V/20A LED Toggle Ignition Switch Panel Engine Start Push For Racing Car Off-Road Vehicle
12V/20A LED Toggle Ignition Switch Panel Engine Start Push For Racing Car Off-Road Vehicle Feature: 1.One button to start. 2.LED indication light. 3.High quality and easy to install,no professional installation recommended. 4.Light weight, stiffness and good-looking,Widely used for vehicle DIY. 5.Easy to turn off in an emergency from any angle, even with glove, will not turn off from vibration. 6.Can be use as the switch of additional electronic equipment (Flashing light,Chassis lamp,Foglight,etc.) 7.Once there is accident happened,rescuer can cut off all power to prevent gasoline tank from exploding. 8.It can control the car's ignition, reduce the impedance of the power supply, improve ignition efficiency, started to accelerate more agile. Specification: 1.Material:Plastic,Metal 2.Input:12V/20A 3.Dimensions: Approx 160X65mm (L * W) Package Included: 1 X Ignition Switch Panel 1 X Set of Mounting Accessories
Price: 39.89
© 2018.
